g5 help needed !
Come talk about our DIY amp project...in english !
sjhusting
g5 help needed !
Message non lu par sjhusting »
No, no problems I didn't cause myself.
I finished my G5 in December, got the hum out in March, and it is the amp I use for recording, practicing, and occasional jamming. I'm quite happy with it.
I'm currently fixing my bad workmanship, and doing some tuning. I'm playing it through a Jensen C12Q in a badly made home built cabinet.
2 questions:
I saw in V2 the rating of R21 was reduced to 2 watts. The Babelfish translation of the explanation didn't make any sense. What is the reason?
Also, R20 has been reduced to 120R. Am I correct in thinking this will permit me to use either a 6L6 or EL34?
thanks
steven
blacksnake
Hi,
120R work good. You can replace this one with a variable bias (see the G5 v2). I had made this circuit and to change tube, just adjust the bias with the trimer ;)
excuse for my little english :oops:
sjhusting
your english is better than my french, which is limited to "une cru classe, sil vous plait"
Hi sjhusting,
Let's have a look on EL34 typical charasteristic (e.g. at http://www.jj-electronic.com/pdf/E34L.pdf)
Ua = 250V
bla bla bla
Ig2 ~15mA
The power dissipated in R21 will be :
P = RI² = 2200 ohms x (15mA)² ~ 0,5W
OK, 2W is quite mojo-overrated, but who cares ? :D
Sheers ...
sjhusting
I get it. The 5-watt was just way overspec'd, which was ok, but now we have to put a huge capacitor in there, too, so space is valuable.
bit by bit I understand more
steven
You bet !
:D
