Hi Steven,
thanks for the update. With all of the info, I would go with a 5751. This might be what you are looking for. The ECC82 has a gain factor that is way too low (20 vs 100!). A 5751 or a 12AT7 might get you close to what you are looking for.
Cheers,
Stephane.
Gain reduction
Yes you can replace the R17 (1M) by a 1M log pot, and you search a clean sound, a master isn't bad idea.
