Page 2 sur 3
Re: Problem with my G5 amp
Posté : 16 mars 2024, 18:07
par louphil
Before you unsold anything and rewire, just perhaps could you do a little test with your DC-voltmeter :
Just connect speaker normally, the common of voltmeter on ground of the circuit, and open fully all control pots . Then measure all voltages plates and grid G1 on the tubes from plate of the power tube to the grid first stage ... Normally, noise have to be audible when putting the red proble on the measured point . These noises will be very tiny on the power stage, but become stronger and stronger as you go to the first stage ... If you have sound on a stage and not on the previous one, you just have located the problem ...
Posté : 17 mars 2024, 14:53
par Papa_Mateo
Input Jack from speaker. I touch one stick from multimeter to star ground and second one to signal pin in speaker Jack and i have connection. Signal and ground is connected. IT shouldn't be?
Posté : 17 mars 2024, 15:34
The pin signal and the ground are connected to the secondary of the OT, which has a very low impedance, which may lead us to think that the pin signal and the ground are connected in a "short circuit".
You can temporarily unsolder the wire leading to the pin signal and retest your jack to make sure there are no shorts.
Posté : 17 mars 2024, 21:03
par Papa_Mateo
Thank you very much
Posté : 24 avr. 2024, 11:48
par Papa_Mateo
Good Today,
I finished rebuild my amp. When i turn the pre Amp on, i have something like this. When i turn power Amp, everything is quite normal, but in speaker is no sound.
Maybe el34 is broken down?
Posté : 24 avr. 2024, 13:20
par Papa_Mateo
The colour of this light is rose.
Posté : 25 avr. 2024, 8:21
par Dr. Nonosse
This is an inter-electrode ignition: The vacuum if bad. You will have to change the EL34 tube.
Posté : 25 avr. 2024, 15:19
par Papa_Mateo
I must say, my el34 died.
I will order a new one and then everything must work. Thank you Guys very much
Posté : 26 avr. 2024, 10:31
par Papa_Mateo
Good Today, i have only one question. Should i change only el34 or together, 12ax7 and el34?
Best regards
Posté : 29 avr. 2024, 8:57
par Dr. Nonosse
I think you only need to change the EL34 tube.
On the other hand, before checking the voltages, particularly, the level of the grid G2 and G3: Check the G5 assembly instructions.
Posté : 01 mai 2024, 11:28
par Papa_Mateo
Thank you Guys very much. I think, all the time the el34 was broken down. When i rebuild my amp, probably i made everything good, but the power tube was dead.
I haven't meet so helpfull people. Thank you.
Posté : 02 mai 2024, 8:33
par Dr. Nonosse
So it's okay, everything works now?
Posté : 11 oct. 2024, 1:31
par Papa_Mateo
Good Today, i ordered a new El34. Still the same. When i turn on pre Amp, power tube Has a light blue colour. When i turn on the power Amp, no signal and power tube Has normal colour without blue. Maybe its output tranformator?
Posté : 16 oct. 2024, 22:56
par Papa_Mateo
Good Evening, i made a mistake with standby button. Guys, do You have a picture how did You connect IT in your amp?
Thank You and best regards
Posté : 17 oct. 2024, 11:56
