G1 schema, etc ? / G1 with 2 x ECC99 !
Come talk about our DIY amp project...in english !
Fernando
Message non lu par Fernando »
Hi. I didn't connect here for some time and now I can't find the section were all the G1 materials were... (schematics, layouts, etc)
I'd like to build one soon.
I was also thinking that it would be great to build a G1 with 2 x ECC99 as power section (like the "EF-Bomb" or the "Dragonfly") since it gives a very rich sound as a result.
I'll be posting in french whenever I have my friend helping with it... meanwhile be aware that I can understand french, just can't write it correctly.
Merci,
Fernando
Modifié en dernier par Fernando le 24 avr. 2012, 19:05, modifié 1 fois.
Fernando
Didi
Re: G1 schema, etc ? / G1 with 2 x ECC99 !
Message non lu par Didi »
Hello Fernando,
I made a G1 few months (weeks) ago, it is the version with Fender tonestack schema modified by Crane is here (I just changed the capa: 22nFd instead of 470nFd)
There's no official layout for the G1 like it is for the G5, you have to look in the different posts to do yours... in my post you'll find pictures of my own layout it can help you :arrow: Didi's G1
regards
Didier
Modifié en dernier par Didi le 19 avr. 2012, 18:56, modifié 1 fois.
roffli
Message non lu par roffli »
Hi Fernando,
the forum has been migrated recently to a new host. Still work in progress. The static section with all the material and resources isn't ready yet for publishing but the boss is working on this (that's what he says :wink: )
Fernando
Thank you both!
Didier, I'll review your material. edit: superb!
Roffli, I understand, I'll wait, I felt silly not finding it anywhere! :D
I can't find any G1 build that tried with two ECC99 for power section or any discussion, I think it would be very interesting.
Do you know if someone here tried?
The EF-Bomb is a great example, but there is also one version of the Dragonfly using a second ECC99 too, although not sure if in the same configuration...
I think it would make a very nice Super-G1 : ) really close to a big amp because of a more rich and complex sound.
Fernando
roffli
Can't wait to see you start the prototyping :wink:
We're always keen to see someone coming up with new ideas or new desgins.
Searching ECC99 on this forums returns 5 pages of hits. Have you had a look at them ?
Fernando
one year ago I was reading everything here, now I'm starting again, slowly
but my skills with tubes are minuscule, I can't adapt the two ecc99 power stage to G1 myself...
or maybe you are being ironical? :D
here is something related:
viewtopic.php?f=10&t=3382&hilit=ecc99
Fernando
bill_baroud
There was at least one attempt at a quad G1, but with 12AU7, by Croquignol: viewtopic.php?f=10&t=3382&hilit=quad+12au7
Problem is, I don't see any schematic, it must have fall into the Great Internet Void :)
edit: wait, no, it's still here!
http://webschem.free.fr/q09n01xe.png
Fernando
Thank you! that's the same link I posted above; it looks like using 12AX7 for pre, not EF86, but the power section is what I mean... :)
Also, in the same thread, Crane suggests to use two ECC99 :)
that's great! maybe it can be adapted wthout problems (with the help of all of you :)
I think if someone with skills see the EF-Bomb schematic will be able to adapt the power section to the G1v3 without problems.
Then the G1's power supply will have to be adapted, I guess, since we are using 2 x ECC99...
The EF-Bomb uses one EF86, then one 12BH7 and another 12BH7 as a dephaseur into the 2 x ECC99s :
http://laird.vectorstar.com/music/amps/ef-bomb
("EF-Bomb revision 5" is the good one, says the author)
http://www.tdpri.com/forum/shock-brothe ... tubes.html
I'd say (I'm an ignorant) in the EF-Bomb the ECC99 grids are in series and in Croquignol 2 x 12AU7 design grids are in parallel.
But the G1 is so refined and nice that I'd like to use only the power section from the EF-Bomb, or just add in the same way the second ECC99 to the G1v3 for a more rich sound and a bit more power and headroom.
merci Monsieur! :D
Modifié en dernier par Fernando le 24 avr. 2012, 19:40, modifié 3 fois.
Fernando
Crane
Message non lu par Crane »
I'm sure the G1 PI will drive well a quad of ECC99. In fact I'm not sure overdriving the quad of ECC99 will give a good powertube overdrive sound, so a cathodyne dephaser like the G1 is perfect.
Just take the TT50 power tranny for the extra heater current and plate voltage, and adapt the power supply (take a look at the EF86 bomb schem)
Fernando
Thank you!
I'll do my best and show it here, I'm really an ignorant, I just can read a schematic and solder, nothing more... but I'll try :S
edit:
I've found one G1 schematic that uses a TT-50 here:
viewtopic.php?f=10&t=3345
schematic named "G1V3 BAXTS v1"
Fernando
but all the grids are in parallel, it's just a different way of drawing ! There is only one pin for the grid !
