Pour ceux qui ont un peu de mal avec la langue de Shakespeare (enfin, ce que je comprends du comm ci dessus) : sur les modèles dotés d’une reverb, le signal en sortie de l’ampli est en inversion de phase avec le signal de la guitare. Un HP sonne mieux quand il commence son excursion en sortant du cab (push) plutôt qu’en y entrant (pull) (toujours d’après la comm). Du coup, sur les modèles reverb, les cab correspondant sont connectés « à l’envers » (i.e. le - du HP va sur le point chaud du jack, le + du HP va à la masse)Care needs to be taken when installing new speakers or adding other manufactures cabinets to our amps. All of our amps that have reverb have a reverse phased output section. What this means is that the signal is in the negative swing as it leaves the amplifier. Traditional wiring of speakers takes the “+” positive terminal and connects it to the tip of the speaker jack, and the “-“ negative terminal and connects it to the sleeve of the speaker jack. When the speaker gets the signal in this configuration the speaker will push first and the pull. If the wiring of the cabinet is “Out of Phase” with the amp then the speaker will pull first and then push. We wire all our cabinets and combos that pair with our reverb amps with the “-“ speaker terminal going to the tip of the speaker jack and the “+” positive going to the sleeve. This way the signal that is in the negative swing as it leaves the amp see a negative polarity at the speaker. Causing it to push first and then pull. Making sure that the amplifier matches the cabinet will result in the amp/speakers working together. This will increase the dynamic range and tone of the system. It will not hurt the amp to have the speaker running in an opposite polarity then the amp. It will just sound slightly muffled and not have the headroom. Amplifiers that have no reverb will want to be wired in the traditional manner.
Je pense que quand on construit ou on achète un ampli, on doit avoir une chance sur 2 pour que la sortie soit en opposition de phase avec l’entrée (nombre de triodes en préamp, par exemple), non ? Et que l’impact sur le son ... mouais ...
Quelqu’un a déjà essayé d’inverser la polarité d’un cab et noté une différence (je ne parle pas de jouer en // sur 2 amplis dont les cab sont cote à cote et où un effet hors phase pourrait être bizarre ...)
D’ailleurs, je suis tombé sur le post d’un gars de Two Rocks sur un forum : « ... I'm not going to get into what it does or if it sounds better one way or another... » (il explique que c’est comme ça qu’ils font, sans entrer dans un débat « ça sonne mieux » ... perso, je lis ça comme « il n’y croit pas lui même » mais je peux me tromper)
