Problems with G5 Amp
Come talk about our DIY amp project...in english !
Message par McColson »
In class A you can bias at 100% of the plate dissipation
A 6v6 has a plate dissipation of 12W
If you have the plate voltage and the current, you have the power dissipation :
P = U * I
So You must check the plate voltage, because 45mA at 300V or à 100V isn't not the same plate dissipation ;-)
Try to bias at 100% of your plate dissipation,a nd tell me how you feel the sound.
Frank
Message par Frank »
McColson a écrit :In class A you can bias at 100% of the plate dissipation
P = U * I
Okay, I knew Mr Ohm :wink: I´ll try it, but i´m a bit scary about tweaking the tube to 100%. In the tubesheets they are talking about 250V and 45mA in class A. So i didn´t know what to do :roll:
Regards,
Frank
P = U * I
Regards,
Frank
250 *0.045 = 11.25W so very near the maximum plate dissipation !
Don't worry to bias your tube at 100% in class A single ended, it's very standard.
Enjoy !
Frank
Message par Frank »
Enjoy !
Okay you win ! :mrgreen:
I´m now at 93% "taux de bias" and it sounds great! :good:
Thanks for your help, i think i don´t change anything to this Amp now!
Now I´m going to build a case for it, but first i need a speaker...
Regards,
Frank
Good, I was pleased to help you.
Frank
Message par Frank »
McColson a écrit :Good, I was pleased to help you.
Nice talking (writing) :wink: with you , thank you (all) very much again!
Bye,
Frank
